Tuning for fuel efficiency???
#31
Originally Posted by 4Gsixty3
I agree with the custom street tune, i will be looking into that next spring.
a custom tune is essentially when you are on throttle in boost, and the ecu is in open loop control
Cruising and out of boost, the ECU is in closed loop control, to this date, how to alter the closed loop control is a bit of a mystery
However, to the OP, what did you expect? The MR is listed at 24mpg..what are you getting?
Im mostly city and avg about 17mpg
#32
#33
Originally Posted by WWIXMR
How do I find out my MPG? What method are you guys using? I fill up like every 2 days, 3 if im lucky. My job is approximately 16 miles away from home. After work I might put on an extra 5-10.
#36
you calculate MPG this way:
1) fill up till it stops by itself; do not overfill as this will mess up how much gas in ur tank u used up.
2) set ur trip A/ trip B to 0 miles right after u fill up.
3) drive until u have to get gas again.
4) fill up till it stops by itself without overfilling. write down how many gallons of gas u've just put into ur tank.
5) divide the miles u got for this tank since last fill up by the amount of gas u've just put into ur car.
for example: trip A = 270 miles. u've just filled up 11.23 gallons...270/11.23 = MPG.
hope i didnt miss anything.
fwiw my stock IX gets 21-22 MPG 40% highway 60% city. after i got my Works filter the MPG went up to 22-23. after i got just my catback it went back down to 21-22 again. but then again it's getter colder here in socal, so that could affect my MPG as well.
also lookin for a custom tune for improved off boost MPG and power on boost as well
#37
I wonder if there is a way to catch the fumes after the exhaust and recycle it into the engine. LoL.
That'd be nice.
That'd be nice.
On a more serious note, if you're calculating MPG based on fill-ups, it's best to use the exact same pump every time.
#38
You guys that are saying to add an intake or exahust to get better mileage are incorrect. Both of those modifcations increase airflow into the engine, increased airflow requires an increase in fuel. If you are burning more fuel per power stroke you are getting worse mileage.
#39
So... in less fuel consuming situations like partial throttle and non boost I could see it making a positive increase.
#41
When your car is driving at speed without changing throttle position the ECU is in cruise mode. Cruise mode is already tuned for minimum pollution and gas savings. the ECU is tuned by every car manufacturer to run very close to 14.7 afr in cruise mode. This setting gives the best pollution control and gas saving combination. To set the car leaner in cruise mode increases pollution.
you can effect your wot gas use with a flash tune, but to do so for gas economy is kind of silly. go easy on the gas pedal.
#42
I understand that staying out of boost can improve the gas mileage. But, isn't there a way to improve gas mileage by keeping the boost/vacuum gauge's needle within a particular vacuum range? In short, can the vacuum gauge be a help in improving mileage? And if yes, then how so?
#43
#44
Adding an intake or exhaust gives you better gas mileage. This is not a rumor or heresay, it is a tested scientific fact. The engine has to do LESS work to produce the SAME amount of power.
dephilron
Oct 5, 2016 08:38 PM
zboost
Apr 10, 2014 08:44 PM
HimynameisWillzyx
Mar 8, 2011 02:57 PM
no0odlez623
Jan 23, 2009 07:09 AM
evoturbo131
Jul 12, 2004 10:21 PM
