another bov thread, haha
I have this problem with my APS BOV, well I don't know if its a problem. If I shift at like 3000 RPM's with just 1-3 psi boost or even in vacuum, it blows off, but it makes 2 very quick "pssh" "pssh" sounds instead of just one, but if I shift at higher RPM's with full boost, then it blows off normally. What's going on here? I even put the stock BOV back on and it does the same thing.
your aps might be a tad too loose as well, i dont have that problem with mine under any boost... your problem might be you are trying to recirc too much and its allowing it to open under partial throttle... the idea is that it VTA's and recircs, but you should only want it to VTA under full boost, tighten it and it should go away.
are you VTA or re circulating the bov?
Originally Posted by ihatepotholes
before u guys start flaming, hear me out first. i got my Greddy rs installed by Turbotrix racing, it was recommended by em, they r a very reputable shop, so i went along. it idles fine, holds boost fine. only thing i noticed is that when i get on the throttle hitting 20+ psi and dump the gas paddle i heard the sound of bov and it felt like the car just hit a wall, is this normal? also in 5th gear if i only give it enough gas to hit low boost and stay in low boost, the air to fuel ratio goes to 10! and the car would start bogging. it is fine when i get on the throttle harder. i know it is an adjustable bov, so my question is that should i turn it softer or harder? and how much should i adjust it? or if i leave it alone, would this harm the car? thanx for ur time guys.
i know there is one i posted in with a pretty detailed picture... dont know where it is though... i would say mine is a little more then half way in though..... any more then that and 2 things happen... the women fall in love with you and you recirc almost 100%
This is a helpful link pertaining to Diverter/Blow-Off/Bypass Valves.
https://www.evolutionm.net/forums/sh...d.php?t=209640
Originally Posted by IX stealth MR
I have the RS also. When adjusting the spring, keep loosing it until when you build about 1-3psi of boost, after you blow off, it should be a clean whoosh sound. If it makes a turkey call noise, its to tight. Also keep both springs in. It seems to discharge the air under low boost quicker than the stock BOV.
just spoke to Jeff the owner of TurboTrix Racing. he told me that compressor surge doesn't hurt the car AT ALL and even the stock DV would surge sometimes. he has a Greddy type S bov on his car for 90 thousand miles and everything is fine. am i missing something here?
