Blew my engine
#48
Originally Posted by gl4662
Would it be possible that the engine just couldn't hold up to it? There was no knocking at all, and the tune seemed to be fine..
What shop did your build? I see you have a lot of AMS parts why didn"t you go to them in the first place? Do you live far away from Chicago?
Hell I drove 10 1/2 hours to bring mine there.
Also Sean is a good tuner.
#50
Local shop tuned it. I'll get some AF ratio dyno sheets for you guys to see. It made 405.8 hp on a Dyno dynamics.. My tuner said that there were some misfirings probably caused by my stock ignition.. I don't know what happened for sure though, they are taking apart my engine as we speak.
Please post the name and location of this shop.
#51
Well, my tuner said that the misfire was probably caused by my ignition set up since it was stock. However, he said that it would not hurt the car.. This shop has done a lot of cars, the owner has a high 700 hp eclipse. So..
#54
1 Post
well, the map was totally wrong, do u redline often? it was 20 degree's outside, did u let the engine warm up? or just go at it like u just came out of fast and the furious
#56
Gas was new, 93 octane from BP. My tuner said everything on the tune was fine, there were no knocks or anything. Just some misfiring. I wonder if it had anything to do with my meth injection.. Is meth affected by the cold? It was like 20 degrees out when i was driving, and my tuner said that it might have been making a little more hp than it did on the dyno, and the engine just gave up..
Sounds like your shop doesnt know what there talking about !
#57
what were you spraying with the alky kit? Methanol, water or a combo? Anything less than 10% methanol would freeze by 20F. Where is the alky kit located, and more importantly, the lines. Maybe you did freeze up a line/fitting or something that stopped the flow.
#58
The alky kit was running 100% meth. The lines run under my seat, through the safe injection then tapped into the intake pipe. So, you guys think this is a tuner related issue? There is no possibility that there was just to much power, and my engine could not hold up to it? Because, the shop has been very helpful to me, and they have done a lot of high hp cars, but not I am kind of lost on what to do.
#60
Yes, but do you think that my engine could have just not been as good as his out of the factory? I mean with the 4g63 i hear a lot of hit or misses, people usually have good luck with it or it blows...
