Whos Reflash is better???
I've been to alot of shops...all I can say is don't go to a tuner that doesn't have access to a dyno (load based dyno preferable). You want to know that your car is actually making more power. Without a dyno sheet, its just guess work. I have also heard that Jester is the shizzle.
there are several different types of flashes. each tuner has a way of making power in their own way. dynoflash makes power different than TurboTrix, WORKS makes power different than Vishnu, etc. they all make the same thing as an end result, however getting there is different.
like it was stated before, it is personal preference. the power curve for WORKS is a smooth curve and leaves some power on the table for safety margin. Dynoflash may make more power at PEAK values, but give you a shorter powerband. follow me??
there are several different tuners on here-you just have to pick one and go with there mods for the flash. WORKS for example, gives you free reflashes for life IF you purchase their parts for the flash. im sure there are others as well, just no highly advertised.
good luck
good luck
good luck
good luck
I would get another flash from Al in a heartbeat when it's time for an update.
OP, there's no way anyone can answer this question. It's way too broad, and you didn't bother to do any homework first. Shame...
