overboost and spiking evo 8
Old Nov 19, 2006 | 10:12 PM
Warrtalon's Avatar
Even if you used the stock lines, you didn't put them on right. The 2 small hoses going to the WGA and turbo have to be in the right order. The hose with the red-painted tip goes to the WGA, and the other short one goes to the turbo. The hose going from the intake to the BCS does nothing.
Old Nov 19, 2006 | 10:15 PM
bigdaddy1p7's Avatar
well the diagram on the hood says that and thats what i did
Old Nov 19, 2006 | 10:17 PM
tripperfx3's Avatar
Ive got the TurboXS (came with the car. Switching to EBC soon) and this happens to me too. I can get it to hit 21-23psi, but it hits boost cut. If i get it to hit 21 w/o hitting boost cut it tapers off to 15 to 16psi. Although i can manage to get it to hit 19 psi steady no problems. I think its just a problem with the TurboXS. Not sure how mine is installed. Havent looked at it yet. Yet again i dont have a tune either, unforunately (not gonna get tuned on 93 when im moving to an area that only has 91...). Another friend of mine is running the Turboxs on his evo and is making close to 600hp with it.
Old Nov 19, 2006 | 10:19 PM
yea im just gonna change it then cause the colder it gets the worse it gets obvisly
Old Nov 19, 2006 | 10:25 PM
thanks for ur help
Warrtalon's Avatar
I'm telling you that you did it wrong. 11-12psi is base wastegate pressure, and that is what happens every time someone messes with the boost system then tries to go back to stock. It just means the ECU isn't currently able to regulate the boost to where it needs to be. You did something wrong whether it be the hoses or the orientation of the hoses.
Old Nov 19, 2006 | 10:26 PM
aight well ill try it tomorrow and see what happens
xexitenglishx
Sep 18, 2008 08:17 PM
Celica2EVO
Nov 6, 2007 09:41 PM
bigdaddy1p7
Nov 19, 2006 10:51 PM
turboex
Dec 1, 2004 07:17 PM
Sunder
Jul 11, 2003 10:46 AM
