perrin tp
perrin tp
so i was cleaning my car today... looked under my car cuase i know i had a tp with the stock exhaust.. upon further inspection i saw that it was much larger piping than the stock exhaust.. and it was made from PERRIN... i have never heard of this company and is it bad that i have that test pipe with the stock exhaust?
Wow! You've never heard of Perrin? Are you new to the performance world? Thought they were pretty well known.
http://www.perrinperformance.com/products/list?model=3
Guess you can add the tp to your sig as one of your mods.
Perrin - good products and quality........that name is out there for sure.......check out JSC Speed......they carry all the Perrin stuff.....I don't think its an issue....propably helps the flow a little......might have trouble getting by an emmisions test though...........
i have a question thou.. i have a test pipe.. shouldnt it throw a CEL light.. becuase right now.. the CEL light is off.. is there a special adapter or something so it doesnt throw the CEL light.. i bought the car used and it came like this?
Perrin also sells a cel fix. I am willing to bet that the previous owner istalled it with the tp
yea there is probably a cel fix on it.
i am kind of confused because in your sig it says u have a RNR TBE with HKS Carbon Ti but u said u have stock exhaust on? did u swap it or am i misunderstanding you?
CEL fix... can someone describe it.. where it goes.. i plan on getting a TBE with test pipe and installing myself and want to know how to put this CEL fix in?
Search man aall your answers are out there and easy to find
http://www.gnvmotorsports.com/catalo...2e9f8f24a5bcdc
anyone? already have CEL fix.. if i get a new TBE with test pipe.. do i need to install a CEL FIX for that?
It depends on which tbe you get some tp have a cel fix some do not. You already have a cel fix so don't worry about it and just use the one from the perrin. Or just get a dp and catback and use you tp that you already have. If you want to get a full tbe than use your perrin cel fix.
