View Poll Results: Waste of money?
Yes
75
27.99%
No
193
72.01%
Voters: 268. You may not vote on this poll
Mini Batteries... Are they Garbage? Waste of Money?
My opinions mini batteries are... they are garbage!
I have a few month old Genesis mini battery... I never had any problems until I disconected it to install my turbo kit...
turbo kit install is now complete... battery is deader than dead
had it tested, came back with a code
F03 internal open cell/ sulfated condition
Originally Posted by KawRider
You lose weight in the front, and they make room for a better IC pipe setup. Your Battery should be under warranty?
Battery is under warranty... so I will go that route
but the fear of going through this every (x) amount of months is a problem...
What will happen in the winter, when the car is parked?
Will probably have to go through this again...
I forgot to add...this is my second battery in a time of 9 months... everytime this happens is when the battery is disconected for a period for about 30 days or more.
Originally Posted by talentsearch301
Install the stock battery in the trunk, will give you the same effect ... yes?
Originally Posted by Boost Addict
Relocate to the trunk. Thats what im going to do. Shift a little weight to the rear and gain a whole lot of room in the engine bay. It's Win Freakin' Win Baby! haha
Mini batteries are a great idea, they save weight and free up a lot of under hood room. If your having issues with them dying get a battery tender. If you want to run a larger stereo, easily removable of course, get an aftermarket alternator.
Google Dominick Iraggi, I've heard nothing but good things about his products and customer service.
Originally Posted by fullboost
If it's frequent that you don't use your car for extended periods, it'd probably do you good to invest in a battery tender. It'll save you loads of aggrivation.
thanx
Yes, please don't relocate to the trunk unless you plan to install a trunk kill switch that sticks out of the trunk. I doubt most of you want to do that...
