Steering tough at idle??
Old Dec 4, 2006 | 09:13 AM
DC2Dorifto's Avatar
I have an IX MR with 4,000 miles on the car. It seems that when the car is parked and at idle, the power steering assist becomes low and takes much more effort to turn the wheel. Just a little gas and it becomes fully assisted again, or even moving a few mph at idle is fine. Any idea what this could be? Defective power steering pump or normal?
Old Dec 4, 2006 | 09:29 AM
rice_rocket88's Avatar
Maybe you're not used to the wide wheels.. all cars are harder to turn than when it's rolling simply because of the resistance the rubber on the cement gives you. Didn't anyone in driver's ed told you that dry steering is bad? Not just on your tires, but it's much harder on the car
Old Dec 4, 2006 | 09:35 AM
DC2Dorifto's Avatar
Well yes this car does have wider wheels/tires in the front than most cars I've owned. But it's like changing the angle at a few mph pulling into a garage gets tough, if it's normal then I will just stfu.
Old Dec 4, 2006 | 09:38 AM
Hmm I think it's just the car.. the power assist isn't crazy powerful like big SUV's or trucks are. The tires are also a big culprit, on many cars once you switch the wheel base size then it's a different story.
I'm sure it's just normal, I've always driven DSM's with wide wheels and the Evo felt no different. In fact, when the evo is rolling it's even EASIER to steer than the other cars.
Old Dec 4, 2006 | 09:52 AM
cfdfireman1's Avatar
What RPM is you idleing at?
Old Dec 4, 2006 | 09:53 AM
DC2Dorifto's Avatar
I'm idling at 700. The car is completely stock.
Old Dec 4, 2006 | 09:56 AM
Don't know about the IX but the VIII is suposed to idle at 850 +or- 50 if that's true for your IX that would be the problem.
Old Dec 4, 2006 | 09:58 AM
rcheung's Avatar
Hopefully its normal but just to make sure, did you check the power steering fluid? Also, just to rule out defective pump, do you know anyone else with an evo you can compare with?
Old Dec 4, 2006 | 10:17 AM
DC2Dorifto's Avatar
Fluid's fine, i didnt even have to top it off when i checked it. I can try another EVO. I can also adjust the BISS to increase my idle to around 850 see if that does anything.
Old Dec 4, 2006 | 10:54 AM
spyderx's Avatar
I don't notice it on my xi. maybe i'm just used to it...
but there is considerable more dampening feel on our ix steering wheel compared to the viii.
Old Dec 4, 2006 | 02:29 PM
DC2Dorifto's Avatar
maybe that's it, I didn't recall feeling it in my VIII RS.
Old Dec 4, 2006 | 02:35 PM
awdboosted's Avatar
Maybe you just need to go to the gym more. I would take it to the dealer and see what they say. Have them put you in another car to test drive.
Old Dec 14, 2006 | 09:31 AM
Well?
Did that fix the problem?
Old Dec 30, 2006 | 06:47 PM
DC2Dorifto's Avatar
for a little while, the problem is still getting worse.
Unfortunately, it takes a good 10-15 mins of driving for it to start... by the time the dealer looks at it all they tell me is "problem cannot be duplicated". Nothing worse than coming in to a slow uturn and suddenly losing PS mid-turn.
Old Dec 30, 2006 | 07:19 PM
CT9AEvolution8's Avatar
It's not a concern. I have the same problem on my 03 Evo VIII and when I've had many shops check it out, they say it's okay and that it is a common problem among evo's.
