wow, just wow.
I honestly don't know enough about fluids and their effects on mechanical systems, much less the ACD. I just don't think you should risk any further damage.
Originally Posted by tarmac4g63
i was told that theres a special tool that u need to bleed the ACD im not quite sure u might have to get it serviced. Thats what i was told
Lord have Mercy, 3SGTE, the word is ABBREVIATIONS. I almost shat myself when I saw the way you spelled it (phonetically, it appears). Otherwise, the abbreviations are nice. Don't think I've ever seen anyone type EWG, IWG, ABV, BMP, or MIL. You should have much more common abbreviations like:
BPV = Bypass Valve (instead of APB)
DV = Diverter Valve
MBC
LICP
UICP
FMIC
TBE
etc... (those may not fit as "guru" lingo)
DV = Diverter Valve
MBC
LICP
UICP
FMIC
TBE
Please do not mix up the fluids in the acd. My friend put the wrong fluid in his AYC and after a few miles his AYC broke. It has to be the specified viscousity (for JDM models ATF SP III for acd and ATF II for the power steering).
AND the system needs to be bled if the fluid in the Oil pressure piping part including the reservoir is changed.
shouldnt need to be bled. What color is the PS fluid he used??? hopefully its not red and you can see the color difference in the resovoir. I'd use a turkey baster and suck all the fluid out of the resovoir and then put atf fluid in and check it over and over and over.
PS fluid and atf like someone else said do have very similar properties, the only difference may be diferent heat viscosities.
Originally Posted by V.8MR
Warrtalon, "Sponsored by evom vendors" LOL, is that nessesary?
