Daily Driven Evo
#32
That's a negative. Just as long as you use the proper fluids and at the proper intervals it won't void your warranty. Us DIYers actually prefer doing our fluid changes. That goes with any other service (brakes, spark plugs, etc.)
#34
#36
Good post, i changed my oil every 3k mobile 1 10w-30 tranny oil, diff oils, Chek every oil change . Change them every other 6k miles. didn know about the radiator flush dont know if thats nessacry,
#37
#41
#43
My buddy uses Q in his RSX S. He says it smoothed out the car vs Mobil 1. Also said he does'nt loose any between changes like he did with Mobil 1.
I dont know you can give it a shot. It oil Im sure it will be fine.
I use the factory fill cause Im **** and thats what these motors were enginered running with.
Try them both and report your findings Id be interested to see how the Q is in an EVO
#44
#45
I think there are a lot of Evo horror stories and that creates a perception that the car isn't very sturdy. Its a car that begs to be thrashed and if you thrash you should expect something to wear out faster then if you drove it tenderly. That being said, there's stupid was to rape your car and then there's driving hard every day. Driving hard won't necessarily break anything major so long as you pay attention to your car and routinely check wear and tear parts. If you drive like FASTNFURIOUS!111! then you should expect something to break.
