Does anyone think or know....
If a LICP being steel or aluminum will make a difference in performance ? i understand the difference in weight, but i dont think a pound or so will matter all that much, but does aluminum have any benefits for performance from the LICP standpoint ?
example... nesei LICP .... steel 2.5 from turbo outlet to IC and then the aluminum version from turbo outlet to IC
They might depending on how each material deals with different temperatures, but it's intercooler piping so material really shouldn't make a difference. I'd definitely go with aluminum though, just the little extra weight savings. Not much I know, but those 1 or 2 pounds add up pretty quickly.
He's talking about from the turbo to the intercooler, not the intercooler to the engine, so heat doesn't really play a role here. He's also talking about piping, not the actual intercooler. ICP = InterCooler Piping.
i already have one, i have an aluminum LICP, but it bottle necks from 2.0 to 2.5... i was looking at swapping into the nesei LICP which is 2.5 straight from the turbo outlet to the FMIC and also is one piece where as the LICP i have now is 2 pieces.... im curious if the aluminum to steel difference would make a difference from a performance stand point, and the 2.5 as opposed to starting at 2 and getting larger would make that much of a difference
i was wondering, main reason is, i like the 1 piece, as well as the AMS pipe i have doesnt have the support bar that the nesei does, i have as you know the older ams version. and i found someone to buy it from me for a fair price that will cover the nesei and shipping and pocket a couple bucks as well.
but if your worried about the performance gains or losses....I think the gains w/ a full 2.5 pipe will be minimal....maybe your butt dyno is more calibrated then mine though
well, i do have a finely tuned rear, or so danyel tells me on a regular basis.... but i think she is biased
as long as i dont get it ported and polished, i suppose i am in good standings
i think they're the same.. just a little difference in weight... it dont make a difference if a driver saves a pound here and there buying lighter parts while he weights 300lbs himself..
