stock psi
PSI doesn't equal power. It is just part of the equation. you have to factor boost pressure with size and effiency of turbo, pipe and TB diameter, compression, A/F mix, timing, exhaust flow, and many, many other things.
Consider that some turbo diesel trucks only run about 5 psi and make LOTS more power than stock Evos.
EDIT: Mine hits 1.4 bar according to the stock gauge. Thats 20.3 psi or so. But the weather has cooled off a bit down here.
Check my Avatar....
Wow, thought this was my thread. Before it got closed becuase it got out of hand the generally conensus is 19 psi and it does taper off.
![](http://i2.photobucket.com/albums/y38/illfadedsole/KeepinItStock2-1-1.jpg)
