Okay so 2 problems. Please help
First of hello to all and hows it going? I havent really been in the forums for a while now. Okay so my problems. The first is that when my car is cold and after warming it up until the needle is a lil above the first line when i start to engage the clutch in first gear my car actually hops and it seems like the clutch is skipping?slipping. It only recently started doing this. Why is this and is something wrong? The second thing is that when i down shift and engage the clutch slowly with little glass i will actually here a whining noise. Why is this please help?
Thanks for the help in advance,
Zac
Zac
The 1st problem can be solved by adjusting your clutch engagement out a little and as far as i know the 2nd issue sounds completely normal. You're going to hear a lot of strange noises come out of this thing....if it gets really bad then it might be a transfer case issue.
i too have started to experience the shuddering while in reverse and sometimes in first gear. it appears to shake and feels like it wants to stall, but i assume as everyone said its just the way you drive. funny thing is this just started happening to me recently. soo i dont know.
i had my radio off the other nite and i came to a slow stop, then reversed, and then sure enough put it in 1st and went on my way (3 point turn). noisest **** i have heard in a long time. the tc noise as its whining to a stop is interesting
