installed mbc, now i get 15 psi spikes and drop to 10
Old Jan 9, 2007 | 06:02 PM
crasher's Avatar
[B]hey guys, just installed manual boost controller (greddy/trust t.v.v.c), I plugged the boost/wastegate actuator, the turbo, and the filter. I ran vacuum hose directly from the wastegate to the mbc, and then the mbc to the bov line, now I get boost to 15, it spikes up to there, and drops to 10psi. I was doing a street tune but still same issue
also, I mounted the mbc to a screw by the block, the mbc gets hot as hell, should I mount this somewhere else?
Old Jan 9, 2007 | 06:07 PM
AngryJonnie's Avatar
You're not having much joy are you.
https://www.evolutionm.net/forums/sh...d.php?t=244457
At this point, if I was you, I'd find a local tuner and get someone to give the car a once over.
Or take everything back to stock and see if it continues.
Old Jan 9, 2007 | 06:13 PM
Warrtalon's Avatar
Yeah, you need someone that knows what they're doing. That MBC is ridiculous, and I've never seen anyone use it, so I can't tell you how to troubleshoot it. HOpefully, the MBC is not the problem, but if it is, we won't know how to fix it. Start out by moving it to somewhere that makes more sense as opposed to almost touching the valve cover.
Make sure you routed the lines to the proper connectors on the MBC - many times, people do them backwards, although it usually causes really high spikes as opposed to very low ones. Also, did you actually turn the boost up? You may be sitting at base wastegate pressure (for a number of reasons) and need to turn up the boost. Have you gone from minimum to maximum on the MBC yet?
Old Jan 9, 2007 | 06:14 PM
xballsport's Avatar
Had the same problem then the guys who installed my mbc put a bigger spring i beleive, all was back to normal.
Old Jan 9, 2007 | 06:16 PM
boscoyo's Avatar
Your instincts was sharp, moving it would be good (BC). WG>hose>BC> Then BC>hose>turboNP. That's it. Put back your stock BOV set up.
Old Jan 11, 2007 | 08:14 PM
crasher's Avatar
oh crap, so its not wastegate>hose> mbc then mbc>hose>bov line???? thats how I have it setup.
Old Jan 11, 2007 | 08:20 PM
littlemilla3's Avatar
You just need it to go: boost source > MBC > wastegate. You probably just need to start turning the boost controller to turn up the boost...
Old Jan 11, 2007 | 08:21 PM
CRX2EVO's Avatar
Rialto, CA right?
I'd try and hide that thing a little better and I'd paint it black. Otherwise, the cops are going to love you.
Old Jan 11, 2007 | 08:42 PM
crasher's Avatar
i pass by cops day and night, i even did a rolling stop by a bike cop, he just looked at me and turned the other way... my luck will not last for long though haha.
okay I reversed my vacuum hose and it seems like it has no boost lag, it going past 21psi which i get scared and lower the acceleration.
QUESTION:
when I do accel, it sometimes peaks at 25psi and i get scared ****less. Ive been reading about these pills in the old lines, do these pills need to be put back into place so I dont get crazy peaks?
Old Jan 11, 2007 | 09:02 PM
boscoyo's Avatar
Turn it down. Turn it all the way down and gradually turn up the boost until desired level is achieved.
Old Jan 11, 2007 | 09:04 PM
boscoyo's Avatar
May be not all the way down, but you get the point.
Old Jan 13, 2007 | 09:49 AM
Tim893's Avatar
my car was doing that too, but i found out my BOV is leaking. but it was at 21psi.
MagicManRed
Nov 2, 2011 06:56 PM
halfnhalf83
Jul 7, 2010 11:15 PM
Bflaker
23
Jun 28, 2008 12:17 AM
crasher
For Sale - Wheels / Tires
Mar 20, 2007 03:07 PM
crasher
Nov 21, 2006 08:32 PM
