MR Boost Gauge
Old Jan 15, 2007, 10:21 PM
STOCK_EVOLUTION's Avatar
Question MR Boost Gauge
searched for a thread to answer my question but couldn't find it... so here is my question, how accurate is the MR boost gauge i have it installed on my EVO VIII non MR... and i just want to make sure it is accurate before i install my boost controller right now i am spiking at 1.3 bar and tapering down to 1 bar... i want to boost it up to 1.5 bar.... the max on the gauge... would this be safe?? THANKS
Old Jan 15, 2007, 11:14 PM
MRedition's Avatar
spiking at 1.3 bar and tapering at 1 sounds right, well thats what mine was like on my dads MR...putting a boost gauge in my SE soon, so I'll let you know in a few days
Old Jan 15, 2007, 11:45 PM
chaotichoax's Avatar
I no longer have it but it was pretty much right on with my autometer gauge so I'd say it's pretty accurate because when my car was dynoed the numbers matched the logs
Old Jan 15, 2007, 11:59 PM
DruMMinStUd06's Avatar
mine matched with my Defi BF...so i'd say its fairly accurate
Old Jan 16, 2007, 05:03 AM
3SgteGuru's Avatar
Mines is Tuned to 23 psi according to turbo trix, but when i stomp on the gass it just goes all the way to the end of the Gauge, but i have a profec b-spec II and i read the Peak boost from it, and its only 24.5 so considering one or 2 spikes thats about right. But I know 1.5 bar is higer than 23psi. So no the gauge isn't to accurate. <wrong
I stand corrected
Old Jan 16, 2007, 05:09 AM
TouringBubble's Avatar
No, 1.5 bar is 21.75 psi.
OP, the gauge is probably as accurate as any other mechanical boost pressure gauge. Yes, you should be able to boost 1.5 bar just fine, but I would suggest that you spend a few bucks and get tuned for it. you'll get more power that way and you will be less likely to damage anything.
Old Jan 16, 2007, 05:15 AM
3SgteGuru's Avatar
Yep 23 psi is 1.59 bar But my gauge just goes as far as it can.
Old Jan 16, 2007, 01:15 PM
rhds13's Avatar
Our MR did that when we first got it, turns out it was overboosting. Get another gauge in there to verify, just run it under the hood and through the passenger window for a couple of pulls.
It spikes past 1.5, but does it hold there, or taper back down to 1.5?
Also, is this only in 5th and 6th gear on the highway, or in the lower gears as well?
Old Jan 16, 2007, 01:21 PM
thanks guys
Old Jan 16, 2007, 01:41 PM
EVO8emUp's Avatar
Actually 1.5 kg/cm2 (MR gauge) is 21.34psig
Old Jan 16, 2007, 01:44 PM
hondafan's Avatar
mine was off by abour -2 psi compared to my greddy electronic and they're both hooked to the same source.
Old Jan 16, 2007, 04:48 PM
kreionic's Avatar
Someone has it right. The stock boost gauge is not in bars. Its in kg/cm. It very close to bars but not exact. 1.5 kg/cm is 1.47 bars and 21.33 psi
Old Jan 16, 2007, 05:10 PM
3SgteGuru's Avatar
^ is a Genius
Old Jan 16, 2007, 07:13 PM
TurboIX's Avatar
1.5bar is not 23psi...if that was the case then I'm hitting 23psi stock!!.
Old Jan 16, 2007, 07:28 PM
06RS's Avatar
This Boost gauge is also standard on the RS. I just thought that had to be said. RS
Quick Reply: MR Boost Gauge
