First 30 days with the Evo MR (former WRX, STi, GTI convert)
#31
Personally I found the pedal movement to be the biggest factor in the smoothness of my shifting. Perhaps that adjustment will do wonders for you If it shifts hard you may look into the upgraded transmission fluids both STI's and Evo's benefit from them.
#33
What exactly do you mean when you say "I cant drive it as fast/easily as the STi"?
Evo's are supposed to be one of the easiest cars to throw around, with much less understeer than STi's. Just sorta confused how you've come to that conclusion.
Also I would love to know how you compare the AWD systems. Unless you've already spent hours flying around a track, or offroad course, I highly doubt your street driving is giving valid indicators of AWD system performance. :\
#34
Fomer Vendor
GunKata, about the clutch, I thought the same about my 8, really hard to get used to. I did the SS clutch line and removed the restrictor "pill" and it made it a new car. If the 9's have that "pill" too (which I assume they do), I would say try taking that out (but you probably don't want to mess with that considering its brand new). But trust me when I say its a world of difference.
#35
The clutch engagement point is a little high, but not as high as my friend's S2000! My Nissan's was just off the floor, so it took a little bit of adjusting to get use to the engagement point of the Evo, but no biggy.
The AWD of the STI has up to a 35/65 front/rear torque split which is different than the Evo. Should give it a bit more of a RWD feel on corner exit.
I personally think the 5-speed of the Evo sucks ***** as far as feel/engagement goes. Honda seems to make the best trannies in that regard. I don't like the feel of the 350Z 6-speed either. Well, the Evo 5-speed does shift much better when you're in full attack mode and keeping up above 4k rpms. For some reason, it just doesn't like to shift quickly in 'putting around in traffic' mode.
#37
^^^ That guy has been watching too much Fast and Furious.... double clutch, pffffttt!
I havent even seen that movie, but why did you feel it necessary to make that comment?
#38
Riiiight. Double clutching leaves you more in control of the car with less jerky motion of just putting the car in a lower gear and waiting for the synchros to do work. Double clutching allows you to quickly and smoothly match engine and tranny speeds for high performance driving.
You're confused and extremely sheltered.
#39
Double clutching is unnecessary and waste of time/effort with a synchronized transmission. All that's necessary is rev matching. Clutch in, blip throttle and downshift, clutch out.
#40
Slowride, well hello! havent been on that site in a while.
For the gusy with the additional clutch comments - thanks, I am going to have to do something.
dreamlike1 - I already stated that the handling was better, but like I also said, the grip of the car just didnt feel the same - which could be the tires, and yes, you're right, I havent tracked it yet. haha, I'll take back the AWD comment! As for the going as fast/easily compared to the STI, well, the clutch obviously affects that process, so that is why I am saying its not as easy. Once I get that taken care of, we'll see where things are at.
