BOV leaking
Old Jan 17, 2007 | 06:45 AM
drewblueeye's Avatar
BOV leaking
So i decided to do a boost leak this morning one last time before i leave for AMS Permorance to have my car run on a dyno, (they are 9 hours away). So i thought hey lets just check to make sure i have no boost leaks. so i hook up my boost leak tester, and try to pressurize my system but it wont pressurize. the BOV is leaking air. It leaks out the hole that connects to the CAI. It wont even hold 5psi. it just kisks it right out. Now i have the FORGE RS BOV. i just bought it last summer when i had my car tuned by Al. And i havent done a leak test since then... all i have for a BOV is either the Forge RS or my stock BOV. I was going to open it up and re-grease the piston but I dont know how to get the Forge RS open.
HELP. Im leaving for AMS in 10 hours
Old Jan 17, 2007 | 06:48 AM
CaymanEvo3's Avatar
Do a search
Old Jan 17, 2007 | 08:03 AM
just an update. first i did do a search and all i find is people asking if they have a BOV leak and no one really gives a straight answer. I was looking for a way to open or fix the Forge BOV. But i took it off my car brought it inside and let it warm up to 75 degrees on a vent in my house, because it got to 2 degrees outside last night. I then went back outside and it worked fine, it must have been too cold.
Old Jan 17, 2007 | 08:52 AM
kduncan01's Avatar
I would call forge, just to be sure.
407 447 5363
Old Jan 17, 2007 | 10:24 AM
evo@24psi's Avatar
Why is MOST peoples 1st answer to a question on here, "Do a Search". Yeah sometimes people post dumb stuff but this was a pretty logical question. Good luck on the fix and the dyno man!
Old Jan 17, 2007 | 10:31 AM
RoadSpike's Avatar
I'd say Google is better for assembly and manuals :P
Manufacturer websites FTW
http://www.forgemotorsport.com/russell/rsinstru.pdf
EDIT:
BTW if you can't read the PDF you can apparently unscrew the the bottom off and get at the spring and piston.
Old Jan 17, 2007 | 02:55 PM
EDL's Avatar
EDL
+1
Clipse3GT
15
Jun 12, 2014 03:13 AM
free ride
10
Nov 11, 2012 04:20 PM
wtf_is_a_evo
Apr 23, 2010 02:15 PM
Clipse3GT
18
Dec 16, 2009 02:48 PM
jj_008
62
Apr 18, 2006 03:20 PM
Quick Reply: BOV leaking
