Clutch squeak
Old Jan 22, 2007 | 09:11 PM
jyndrus90's Avatar
Clutch squeak
When i press the clutch down it sounds like air blowing. But when i press the clutch slowly it squeaks. Could it be a spring or something. New stock clutch was put in about 10k miles ago. This happens when i push my clutch down. Any ideas? Thanks
Old Jan 22, 2007 | 11:07 PM
heavens turbo's Avatar
maybe clutch master? was that changed also?
Old Jan 23, 2007 | 02:26 PM
jyndrus90's Avatar
Whats a clutch master? The cylinder. I have a 03 with 45k miles you think its still covered under warantee?
Old Jan 23, 2007 | 02:47 PM
Dumb_Dog's Avatar
lubricate the release fork
Old Jan 23, 2007 | 03:03 PM
l2edline's Avatar
yeah do that. thats what happened in my old car. I WD-40 that thing and problem solved.
Old Jan 23, 2007 | 04:08 PM
jyndrus90's Avatar
Where is the release fork located? How do i get to it?
Old Jan 23, 2007 | 08:28 PM
hondafan's Avatar
it's sticking out of the front of the tranny under the airbox, put some grease on the ball that contacts the fork from the slave cylinder.
Old Jan 23, 2007 | 08:48 PM
MasterNater's Avatar
I'm really hoping you aren't mistaking the bov release for a clutch noise.
Old Jan 23, 2007 | 09:14 PM
geevolution's Avatar
LOL
Old Jan 24, 2007 | 06:47 AM
jyndrus90's Avatar
First of all ur bov doesnt go off when ur car is off. 2nd is squeaking and i didnt metion when acclerating of hitting the throttle. But if ur cars bov goes of when u just push the clutch at idle maybe u have a problem
Old Jan 24, 2007 | 07:03 AM
MitsuJoe's Avatar
You may also need to grease the spring on your pedal assembly for the clutch.
Old Jan 24, 2007 | 11:41 AM
easy big guy, you never said you were pushing it in when the car was off
Old Jan 24, 2007 | 02:20 PM
Dumb_Dog's Avatar
pull off the rubberboot at the base of the slave cylinder, that's where the release fork is at.
nor11384
Nov 21, 2022 08:23 AM
black ralliart
Jan 17, 2017 12:30 PM
CaptainSquirts
Aug 6, 2016 08:32 PM
nor11384
Nov 22, 2015 02:31 PM
tboboy
Jun 20, 2007 10:38 AM
Quick Reply: Clutch squeak
