Tuned / MBC ?
Old Jan 29, 2007 | 07:22 PM
lanevokai's Avatar
Tuned / MBC ?
I had my car tuned with an ecuteck flash in the past without my MBC install . apprently my tuner raised my boost for me and i'm now running 20-21 pounds. Do i need to install my MBC? or will it just be a waste of money since my Boost is already increased. I heard that other have had their cars Flash with the Ecuteck and still have the MBC to hold their boost ? is this true if so do you think i should install my mbc or just leave it because i already got my car tuned. You see i ask this because i see many people with Ectueck flashes and having MBC install so i thought why do we have an MBC anyways when we already have our Boost raised from the Ecuteck Flash.
Old Jan 29, 2007 | 07:25 PM
lanevokai's Avatar
any Techs care to comment? greatly apprecated.
Old Jan 29, 2007 | 07:28 PM
bluebyu36's Avatar
im no tech but i like having the option of being able to control the boost.for example i lower it in the snow,and raise it when i have race gas.
Old Jan 29, 2007 | 07:29 PM
Warrtalon's Avatar
The EcuTek flash doesn't raise boost - it just removes some of the taper. You install the MBC if you want full control of boost and want to raise the peak boost. You are in Utah on an VIII with 91oct, so you could install it and run a solid 21psi then run 24-25psi on race gas at the track, but if you don't ever plan to change your boost in the future, then you're probably fine how it is now.
Old Jan 29, 2007 | 07:33 PM
lanevokai's Avatar
o i c thanks since my car got tuned already and i believe it's tuned pretty moderately can i just install my MBC and just turn it up by about 1 or two clicks the most and still be safe ?
Old Jan 29, 2007 | 07:35 PM
bluebyu36's Avatar
i would not put it higher the 21 on 91 octand gas!with race gas you can turn it up more like warr said.
Old Jan 29, 2007 | 07:50 PM
lanevokai's Avatar
ok thank you / thanks everyone
Old Jan 29, 2007 | 09:28 PM
Warrtalon's Avatar
I would not raise boost when you're tuned for a lower boost level unless you raise the octane.
Old Jan 29, 2007 | 09:47 PM
Evo8's Avatar
Get MBC (it will have your boost solid up to a redline) and then get more parts and get retuned....IMO the best way to go without wasting money on pointless tunes
Old Jan 29, 2007 | 09:58 PM
evobeatsti's Avatar
where did you get your tune done? i am a utah local and think i found someone to tune my car but am trying to find someone else with experiance with them so who tuned your car? ps i love your quote evolution[OH]
