Headed To The Track
Old Jan 30, 2007 | 12:11 PM
evoIX15's Avatar
Exclamation Headed To The Track
hey guys, i am going to the drag strip this weekend and I have a stock WW IX...it gets the job done, dont get me wrong. But im looking for a very quick upgrade that can help performance in the next few days...do you guys have any suggestions? I was thinking just be simple and go with a drop in air filter...let me know. thanks!
Old Jan 30, 2007 | 12:13 PM
Greg K's Avatar
what sort of track? lapping or <shivers> drag racing.
for lapping I'd suggest real break pads, high temp fluid and steel lines.
for drag racing I'd recommend saving money for a new clutch.
Old Jan 30, 2007 | 12:14 PM
Smike's Avatar
Driver mod - i.e. learning how to launch it...Ill dig up my 2step tech...
Flash is a great simple mod that will make a difference. A filter may add a couple of whp, but not as much as the flash.
Old Jan 30, 2007 | 12:17 PM
Smike's Avatar
If drag racing, here is my 2step walk-through:
https://www.evolutionm.net/forums/sh...75&postcount=4
If track, yes like Greg said, upgrade the brake pads and go to a DOT4 fluid.
Old Jan 30, 2007 | 12:22 PM
evoIX15's Avatar
im headed to a quarter mile drag strip
Old Jan 30, 2007 | 12:29 PM
jmartinez1170's Avatar
if you want the best quick and help out alot get a drop in filter it just opens the air better then stock.
The best way to go is to go stock a few times look for your best time. Its going to take you a few times at the track to get use to the light 2 step and all that good stuff.
Then start doing one mod at a time. Drop in filter, then after you get a few runs in get some more time. Get a turbo back with a highflow or go test pipe if you do use a test pipe you will need to retune your car so the cel light wont come on . Then start modding the car untill you like it the way it is.
Old Jan 30, 2007 | 12:31 PM
Smike's Avatar
Originally Posted by jmartinez1170
...test pipe you will need to retune your car so the cel light wont come on . Then start modding the car untill you like it the way it is.
The tune isnt for the light, to be clear. The mech. O2 fix or the O2 sim. will get rid of the SES rear O2 light associated with a HFC or TP.
Old Jan 30, 2007 | 04:44 PM
Warrtalon's Avatar
MBC (set to 22-23psi) and/or quick flash would be the best, quickest, and cheapest mods to do between now and when you go to the track. The filter won't really do anything.
Old Jan 30, 2007 | 05:40 PM
sonicnofadz's Avatar
Good luck, try not to break anything
Evoleader88
Apr 15, 2011 09:03 AM
varner88
Northeast Region
Aug 9, 2010 03:00 PM
CLOS_38
Jan 26, 2008 09:40 AM
evodave
Jul 14, 2005 12:18 AM
FrOsTy eVo8
Automotosports - Illinois
11
Apr 21, 2005 10:07 AM
Quick Reply: Headed To The Track
