O2 Sensor Problem
O2 Sensor Problem
ok, i dont have my oem o2 sensor so please nobody ask about it...i went today to mitsu to get a bosch o2 sensor installed on my car. The bosch o2 sensor was designed for my car. "and it was the rear o2 sensor" before i got it installed i had a cel light and when i turned on my ac my car would sometime choke down, and when i turn on my high beams the stock water or engine temp by the tach goes up. after the bosch o2 sensor it still does all of this. The guy that installed it says that i have to have the stock one in order for my cel light to go off. He also tole me that if i get a wideband o2 it would go away.......can anybody help me the freakin stock o2 sensor is freakin four hundred dollars...does anybody have any advice to correct my problems..... thanks guys...
You're just a complete mess, and that guy doesn't know what he's talking about...a wideband o2 would make the CEL go away? Unbelievable...
See if you can get a used o2 from someone on here. The CEL will go away with a CEL fix, but I highly doubt the rear o2 has anything to do with your other problems. You never should have lost/thrown away/broken your stock o2 sensor...
hey wart, do u think its my bushcur battery that is the only other thing it could be...i cant think of what it is...its worrying the crap out of me.
i was also thinking you could do the old spark plug defouler trick, you buy one from the autozone help section and drill it out so the o2 sensor fits in it, then install the whole thing in the o2 bung and it takes the sensor out of the exhaust stream and helps get rid of cel. this may only apply to N/A engines going turbo though
evovin
14
Dec 5, 2008 06:15 PM
deadbeatrec
15
Apr 19, 2008 07:59 AM
Deezee
17
Feb 16, 2008 12:39 PM
