Clunking sound from FRONT/MID section of the car....what can it be?
Old Feb 1, 2007 | 05:12 PM
Dr.Sound's Avatar
every time i make a tight turn at low speeds i hear a clunk coming from front/mid section of the car.
it also clunks going over bumps if the steering wheel is turned.
could it be the swaybar bushings? this started when temperature dropped a couple of months ago. never gets REALLY cold here in cali, but still colder than usual.
Old Feb 1, 2007 | 05:25 PM
SickSilverNLow's Avatar
hmmmmm...i live in a very cold place and it gets down to like 15 deg. sometimes and i never heard that sound . I would also like to know why this would happen!!!
Old Feb 1, 2007 | 05:30 PM
Dr.Sound's Avatar
maybe i should add........doesnt matter what gear i'm in, sometimes i start from 2nd.
it will also do it if i'm in neutral. so i dont think anything is wrong with tranny.
Old Feb 1, 2007 | 05:31 PM
xLaNcErEvOx's Avatar
im getting a sound like that too, but i think its because my shocks are going out...
Old Feb 1, 2007 | 10:08 PM
Utah-evo's Avatar
Me two time for coilovers
Old Feb 1, 2007 | 10:14 PM
elhalisf's Avatar
it seems to be a comon noise with the evo. did u have the clutch replaced or tcase removed recently?
Old Feb 1, 2007 | 10:20 PM
heavens turbo's Avatar
rubber shrinks when cold, so if it happens cold, it may be a bushing in the swaybar, etc. saturn ions do a clunk thing with the swaybar bushings, cold or going slow over bumps.
Old Feb 1, 2007 | 10:23 PM
RobDogg's Avatar
I have the same exact prob. i think the spring is not seated properly. That happens when you jump the car! I think your shocks are still good have some one check your springs.
Old Feb 2, 2007 | 11:28 AM
Dr.Sound's Avatar
no, nothing like that.
thanks for replys guys.
Old Feb 2, 2007 | 11:49 AM
kiley_sean's Avatar
I heard that that is one cause of it (spring not being flushly seated), but I just installed coilovers 2 weeks ago and the noise is still there.
Mine only happens when the car is still cold and I am barely taking off in first or reverse. Once the car has been driven for awhile (heats up) I don't hear it anymore. It just started back in December when it got cold here.
I doubt it is the swaybar bushings, I've had them dry out and/or loosen-up before on my other cars, and you usually hear a low pitch squeeking noise when you go over bumps. It sounds like your struts are blown, but it's just the bar rubbing inside of a dry bushing (no clunking).
I think it is the swaybar end links binding-up in the cold.
Old Feb 2, 2007 | 11:53 AM
XK120's Avatar
i had this problem a few weeks ago..I got worried because I thought that it was my drivetrain or something...after a 2nd gear WOT pull it went away for good..weird huh
Old Feb 2, 2007 | 11:56 AM
Extas's Avatar
Mine does this and I don't know why. I'm gonna ignore it till it brakes! I'm sick of it and everything checked out fine.
Old Feb 2, 2007 | 12:03 PM
SEEnoEVO's Avatar
^+1 Can search forever and never find it sometimes.
Old Feb 2, 2007 | 04:53 PM
Dr.Sound's Avatar
on my 2 previous cars (both mazdaspeed proteges) the "clunk" was a never ending story.
the rear swaybar bushings cluncked all the time. dealers had 5 TSBs out for them, but none fixed the problem.
it sounds like a low "thud".
bu maybe you are right, kiley, maybe the sound is produced by endlinks.
guess i'll have to wait untill it warms up in a month to see if it goes away.
sux.
Old Feb 2, 2007 | 05:34 PM
kiley_sean's Avatar
What ever it is, it's very common with Evos (from all of the threads I've searched), happens mostly when the temperatures are cold, and doesn't present much of a problem other than noise (that I have seen from the other members).
I'd still like to find my culprit, though.
Quick Reply: Clunking sound from FRONT/MID section of the car....what can it be?
