Cold start noise!
From what i understand this happens to a lot of IX's. I happened to me to I replaced pulleys and belts but the noise returned. I am just going to let it be for now until I can find out what is causing this noise and keep it from coming back.
I have a 03 EVO VIII and it makes the whirring/scraping noise when started it sounds like a power steering pump running dry.......it does it on cold starts in the morning.
I just had my timing belt replaced with a kevlar one, and the tensioners and now I have the noise, I did not have this noise before the service. They didnt replace my pulleys though.
so does anyone really know what this noise is? I think its powersteering
I havent had that happen on mine yet, however i need to get my cold start map retuned because my car HATES running on cold mornings (below zero) and you literally HAVE to let it warm up for 5 minutes before the rpms will go over 3000. Sounds like a machine gun because the timing is retarded too much ( i think?)...pretty sure ive scared a few neighbors lol
this happens to me too, and for me anyway, it is the belt. it gets loose after a while and i just needs to be tightened. in fact mine started doing it again, i need to go fix it
