Thread of Cuda moved, here's pics of Evo
#31
How much weight savings on the CF top vs Aluminum, since the RS is aluminum. As for the hood, the Aluminum is slightly lighter than the CF so not sure how much would be saved when comparing to the lightweight Aluminum on the RS. I chose CF doors, since they were steel. Aluminum vs Steel makes up for part of the factory savings/weight figures. I would imagine that the Alum top is about the same if not lighter, unless the CF is single layer without the supports. Any ideas as to the comparisons?
#35
That's combined. Front doors saved ~20lbs each, back doors were 15 each, deck was about 10. Not much savings for the cost. That's why I started a thread a while back about the cost per pound of weight savings. By doing that, we could put a sorted order list out that would show what each change should be, based on expense. No way to save 200 lbs without leaving the doors, deck and hood completely off.
9sec9
242
Oct 22, 2008 01:49 PM
9sec9
10
Nov 26, 2007 08:57 PM
