door panel removal worth it?
my debit card was on the passenger door sill and it fell through the slit. will this cause any damage to the motor for the window or any wiring. is it worth it to pop open the door panel. and if i do take the door panel off, how easy is it. i saw a door panel removal for an evo rs in the how to section but was wondering if it was the same for an evo with power windows.
thanks
thanks
The motor for the power window unit is pretty much sealed, so I find it hard to believe that your card would cause problems with that. I guess its possible that the card can get jammed somewhere and interfere with the window going up and down... but thats about it.
that being said, it takes only about 10 minutes to remove and replace the door panel. do a search, there are several how to's about this.
it's easy and worth it. do it. all you'll need are a few simple tools like a pick and a screwdriver as well as some common sense about how to take stuff apart.
I'm sure that someone has done a writeup about how to install speakers in the doors, so I'd recommend finding that thread if you need specific instructions.
thanks
thanks
lmao funny story
i would just leave it down there, call the credit card company n get a new one..
if it starts to make noise (which it probably will) and annoy the hell out of u.. then remove the panel n get it
theres a swew by the handle, theres one in the cup looking thing that you pull to close the door, and a couple towards the front portion of the car with caps.. take those off then pull from the bottom upward and itll kinda peel off... its all feel.. cant really break it.. once you have every off you need to pul upwards to get it off the window part.
cheers!
cheers!
ries
13
Jan 10, 2010 06:15 PM
vtluu
15
Feb 7, 2008 09:40 PM
bigd31388
Lancer How Tos / Installations
Dec 2, 2007 12:22 PM
jedimaster
Oct 6, 2003 09:17 AM
