Downpipe and Megan Catback WITH stock cat?
Does anyone know if I will run into any sort of problems installing a megan 3'' Downpipe and Catback and then keeping the stock cat (not putting in high flow or testpipe)?
Thanks!
Thanks!
I had that setup for a week before my test pipe came in, it sucked ****. I made no power from the downpipe at all with the stock cat in place, and when I installed a test pipe into the system, I felt like it gained more HP from just the TP in place of the stock cat than the rest of the exhaust system without it. Just get a test pipe, or skip the downpipe entirely and just get a catback.
I have a catback... but looking at downpipes and testpipes... basically what Im saying is did you find any sort of mechanical problems running your downpipe and cat back (if you had this) with a stock cat..
I would use this setup for a bit before I decide on what to replace my cat with.
