installing clutch bonjo bolts ---best tip , u can do it in less than 5 min
Old Feb 23, 2007 | 09:16 AM
yesevo's Avatar
installing clutch banjo bolts ---best tip , u can do it in less than 5 min
hey i just installed ss clutch line and remove the restrictor too. ( get extra 2 copper washers for the restictor)
i just wanna help u guys installing 15 mm banjo bolt, ( we all know how pain in the *** to get this in)
first of all u need to hold the 2 copper spacer(washers) into banjo bolt. so you dont drop it off while u trying to install it.
just get the 3m double tape or masking tape to hold the spacer onto the bolts.(just wrap it around)
now u need to put the banjo bolt with ss line on to the clutch cylinder.,
u need to use right hand to grap banjo bolt and turn the bolts in.
and you need to go from top .
remember those two~
USE UR RIGHT HAND TO SCREW THE BOLD IT IN.( using ur left hand to turn the bolt will never work period)
AND U NEED TO FEED THE LINE FROM THE TOP
also it is good idea to have the wrentch that turns like socket ratchet..
and u can also adjust the angle.....available at SEARS...(about $125 for 7 pcs-set.i know it s expensive but worths every penny ,,,i love this one,)
HAPPY EVO MODDING DAYS~
Old Feb 23, 2007 | 09:36 AM
tkklemann's Avatar
Never installed a bonjo bolt before, only banjo's.
OK, I am a smartass.
Nice tip, I did it exactly that way a while back and it worked.
Old Feb 23, 2007 | 09:57 AM
althemean's Avatar
now it reads banjo....happy?
