Greddy EBC spiking crazy in snow...im from Fl
i decieded to take a last minute trip to go skiing in west virginia. havent driven the car in weather below 60 so that just requires a minor adjustment, just 1 or 2 percent gain.
well i drove and got down to 30 degree weather and i started getting higher spikes, 28+ pounds. i'm not running methanol, just 93oct & 20 pounds.
i now have it turned down to wastegate and its spiking 26 pounds... pretty crazy.
is that normal in 10-30 degree weather?
ps.... i now understand what everyone means when ya say driving on sport tires in the winter is stupid. it snowed couple inch's last night and we were driving my car back to the room from a restuarant on the mountain, 2 mile drive.... anything more than 5-10 mph the car was all over the road... possibly scariest thing ever, i've never felt like i have no control over the car.
cheers!
cheers!
what are your profec settings right now? you helped me with my set-up originally, but i had to make alot of adjustments to compensate for the colder temps, so the problem may be that you're set-up for fl temps/weather conditions.
im back home now, checked all the lines and its running full boost... im on meth again so im not scared to get off the gas....
backed the timing back a ton and im running 33 pounds of boost... or at least thats what the profec is reading.... my load is threw the roof...
tomorrow i'll take my time and ill check all the vac lines one at a time and go from there
cheers!
cheers!
same here...im in jersey and with the temp drop from like 40 to 15 i have to turn down my set from 55% to like 30%+/-. If i dont i i hit the boost limiter and get nasty backfires, im guessing i would see atleat 25 psi if i didnt turn it down. I think it is an inherant problem with the greddy. I am constantly adjusting it with temperature varations.
