Anyone using a Ralliart drop in filter...?
not sure what the deal is, but it's just too big to go in the box... it will fit in the box if i put it in upside down... at least i think it is upside down...?
the Ralliart Logo should be facing up i assume, as there is a plastic honeycomb grid on this part of the filter, and the underside is just a green foam pad...
so what gives...?
anyone else using one of these...?
for $115 this thing should just drop right in...
so what gives...?
Re: Anyone using a Ralliart drop in filter...?
so what gives...?
so what gives...?
I am running a RalliArt drop in. It fits fine and there is only one available for the evo so I know u have the right one. I actually encountered the same problem. Your are trying to install it upside down .... you would THINK that the Ralliart logo faces up ... but it actually faces DOWN (the grill side & ralliArt logo down) if I remember correctly. Sorry but its no much of a show piece.
so the green foam points up...?
if that's the deal, then i'm cool...
just hit me back...
Thanks guys...!
just hit me back...
Thanks guys...!
Do you Evos feel any difference at all after you install this filter?
Are these filters reusable/cleanable or do you need to throw them away and get new ones after a certain mileage?
Originally posted by wmcorcor
What other drop-in type air filters are people using in their EVO's?? K&N...?
Originally posted by evo1
No this filter is washable and good for life (supposedly). I thought I felt the car pulling a little bit more freely after install, but it isn't a huge gain. It's also supposed to improve gas mileage but I'm not sure if it has. It's more for piece of mind than anything else .... and you can rest assured that it will keep dirt out of your intake as well unlike some of these racing suction kits where the filter has to be changed a monthly basis, lol. it appears ... at least in theory that it allows more air (volume) to enter the intake, but it's not a huge gain in power as with most aftermarket air intakes. I decided to go with it until I can find an open air filter kit that proves to add a substantial increase in power ... the kits that are currently out add power ... but not as much as I would like, and they are more for hearing a cool pssssssshhhhhhhttt sound or hearing the BOV more if anything. Just my two cents.
Nice, thanks for the info
I would not expect to see any significant gains from an intake modification for a basically stock motor until someone brings a true CAI unit to the market. APS has one for the VII but has not yet confirmed that it will work with the VIII or the US EVO.
PS - Not interested in re-opening the CAIs don't increase performance on turbo cars because of the turbo's inherrent heat ,thank you very much.
Speaking just for myself I want a drop-in filter (no modifications) to get better air-flow without sacrificing reliable filtering. Also having a cleanable filter element is better than buyng one cheap one after another. In the other turbo cars I've owner I had noticeable, althought not dramatic gains from a K&N drop-in filter.
Personally I don't plan any mechanical mods since I don't race this car and I'd rather not play warranty roulette. Also after modding out three other cars it gets a little old having to take the car to 5 different mechanics depending on what you think may be broken.
I will do cosmetic and simple drop-in mods but that's it and I think the air filter is an easy one.
