wiring new mirrors
Old Mar 16, 2007 | 05:53 AM
evo150's Avatar
wiring new mirrors
couldnt find anything through searching. i ordered the rexpeed ganador look side view mirrors and want to wire them up. do you know what color wires from the stock mirror harness is positive, negative, and ground? thanks
Old Mar 16, 2007 | 02:17 PM
boost<3's Avatar
off topic, but when you get them installed please post up pictures thanks.. sorry i couldn't help though I want to purchase these too but was worried about wiring them up..
Old Mar 16, 2007 | 02:41 PM
evo150's Avatar
here you go. not the best pics
and more pics here https://www.evolutionm.net/forums/sh...=252011&page=5
Old Mar 17, 2007 | 08:48 PM
barneyb's Avatar
It is more complicated than that. There are eight switches in the control. There are two motors in each mirror, up/down and left/right. The switches reverse the ground so the motors can run in both directions.
Brown connects to both motors. The other two wires connect to one motor each. If the mirror doesn't run in the correct direction, reverse this second set of wires.
Old Mar 17, 2007 | 08:57 PM
Curt941's Avatar
I got mine on the way, have to go pick them up at the post office on monday, can't wait.
And that car looks friggin sick!
Old Mar 17, 2007 | 09:53 PM
PTevo's Avatar
This worked for me:
driver side: red-blue, black-green, white-white
pass. side: white-white, red-blue, black-yellow
Old Mar 18, 2007 | 08:11 AM
evo150's Avatar
Originally Posted by PTevo
This worked for me:
ill try this out and let you guys know
Old Mar 19, 2007 | 09:16 AM
evo150's Avatar
This worked for me:
worked perfectly
i first cut the stock harnes from the stock mirrors. using the driver side harnes i wired it up following the above to the new driver side rexpeed mirror. after all connections its completly plug and play. i then moved on to the pass. side and did the same.
Old Mar 19, 2007 | 09:20 AM
LoRo's Avatar
What is your visability with these compaired to stock?
Old Mar 19, 2007 | 10:09 AM
Curt941's Avatar
Good info, i'll be using this tommorow when i install mine
Old Mar 19, 2007 | 01:00 PM
evo150's Avatar
its good. its not as good as stock because you dont have as much mirror but they are functional unlike the ones that are for lhd vehicles
Old Mar 19, 2007 | 06:45 PM
Trueno86's Avatar
Got mine installed as well. Are you guys getting any wind noises from the mirrors. I am getting some high pitch, whistle noise when cruising above 60mph.
Old Mar 20, 2007 | 02:12 PM
evo150's Avatar
i am getting the sound too. i double checked and the bolts are tight and stock "gasket" is seated properly. oh well as long as they dont leak water
ej13
May 22, 2015 06:14 AM
95lsvtec
Mar 3, 2015 01:03 PM
rovanpera
Mar 4, 2009 09:26 AM
jvallesteros
Dec 23, 2008 04:09 PM
KPerez
Jun 26, 2008 10:39 AM
Quick Reply: wiring new mirrors
