what does the ETACS look like?
Old Mar 21, 2007 | 09:21 AM
Jazzie604's Avatar
Im just trying to do some testing to figure out why my park lights are staying on all the time, and Im trying to make sure of what the ETACS ecu is. Im assuming it is the red box bolted on to the back of the interior fuse panel. can anyone confirm this for me?
and has anyone ran into this problem with their interior lights staying on? This car is nearly stock, with only a boost guage light tapped into the dimmer switch, and an AFC tied in(dont know where, I was told it was installed at Buschur, 2-3yrs ago) any help would be great.
Old Mar 21, 2007 | 10:57 AM
ries's Avatar
what does the ETACS control? I know the red box your talking about has something to do w/ power windows and doorlocks but not sure about it being the actual ETACS ecu...
Old Mar 21, 2007 | 11:09 AM
ries's Avatar
here's what I found in the manual
Old Mar 21, 2007 | 11:11 AM
ries's Avatar
the ETACS controls a bunch of stuff off the column and includes the power windows, doors, keyless entry, tones/warnings, etc...
dont know how to dix your problem but I hope this helps
Old Mar 21, 2007 | 11:21 AM
LancerEVA06's Avatar
might be a faulty relay in the front ecu (the front ECU is a bunch of relays and a FET, and a few other minor things). Best way to check is pop out the front ECU, take it apart and energize the seperate relays see if they are working properly... or try someone elses front ecu. It could be a short also, somewhere between the column (switch) and lights. If you have an aftermarket alarm, double check the connections.
Old Mar 21, 2007 | 01:44 PM
Jazzie604's Avatar
cool, though I wonder if that is inside the car or under the hood. hmm...
and where did you get the manual, is there a place online?
If this were the case, I would think the taking the front ECU out would then turn the lights off. am I mistaken in how that works?
jhoganusaf
Feb 26, 2024 08:38 AM
Michael Roestel
Sep 21, 2017 09:00 AM
blackmambe_evo7
Sep 13, 2016 07:54 AM
acamus
Jul 28, 2009 10:48 PM
Quick Reply: what does the ETACS look like?
