Is anyone else's oil dipstick poping out?
How is this a common problem?
I know a lot of people with Evos and working at a shop tons of them have come by. None of them have dipsticks just shooting off.
I was being serious when I asked if you plugged it in all the way. Has the only time it happened after you changed your oil?
Evos don't normally blow by. It's not a Subie.
when it was spilling out the dipstick read like this l -------l
now its not poping out however the dipstick reads like this l ----l
Dipstick Retension Spring URL
Get that, and consider it fix... or use a zip tie if you like.....
yeah, its blow by. cylinder rings are usually the cause. do a compression test, and if it doesnt look good, do a leak down to narrow down the problem.
p.s. make sure you at lest patch the problem asap with a dip stick tie down, or else you risk an engine fire from oil on your exhaust mani.
Before you jump to conclusions....fix the simplest first.
Try changing the two o-rings on the dip stick. I have replace a few on friends cars..
New o-rings made it fit tight again.
Check your PCV system. Is it vented to atmosphere, or is it still recirculating (i.e. stock)?
I never ran into this issue on my stock setup (and that was even _with_ blow-by), but I do run into it with the AMS VSR intake on my car when I road race it, so I use a zip tie these days...
l8r)
l8r)
The other thing that it might be is that you have too much crank pressure, AKA, your not running a catch can, and in the process of doing so the air has nowhere to go so it reliefs itself through the Dip stick....
Either way i dont think that you have a serious problem on your hands. You can run a compression test. and a leakdown test but i dont think that you have anything to worry about.
Anthony
Kevin Knight
Nov 26, 2016 08:56 PM
omniprobe
Feb 25, 2008 09:44 PM
