car got tuned today
Niceee.... if ur really running 20 on pump n making 338 whp man tat a lot... forget cams do meth injection & run around 26-28 psi n see how u burn all 4 tires.. u can do cam s + meth.. but remember ur on ur stock bottom end... so if u do tat.. make ur bottom end stronger.. coz u do not wanner blow up..
well al said and i quote i probably if not def have the highest hp evo hes seen on stock cams stock ecu and he didnt mention your car haha when i have cams and meth ill be over 400whp and when you do cams and meth youd be lucky to see 365 IF that on the 9.8 hotside
nice numbers mate!
You definitely need cams! you have a big turbo, and all the right parts to make big power!
With the cams probably you will see mubers around the 370whp area on pump and then if you use meth definitely you will pass 400whp!
