Evo saved my life
#46
awd didnt do anything..... awd helps when ur going thru a turn on the gas, when ur off*** the gas i cant see how it could affect anything....
#47
#51
What happened after the accident? You can't really stop in that tunnel. Did you give your name as a witness?
You have to treat an Evo's braking ability like a motorcycle's, as far as following distance. The Evo can out-brake most cars on the road, so you should leave more space in front of you in case someone slams their brakes. Also, try to anticipate slowdowns and watch two or three cars ahead.
I realize, if you leave too much room in traffic, some jerk will tend to cut in front of you, but I'd rather lose two seconds than rear-end someone or be rear-ended.
#55
To the OP, glad you and your ride made it out
