fix engine or sell as is? serious issue
#32
Damn....Im going to check my oil right now! Spun rod bearings can be repaired unless you blew a hole in the block. I say you buy the parts and have a nice time putting it back together.
#33
Only 2 qts and you put 5 in ??????? Either you did not or the engine burns a lot of oil. Which you would see pouring out the back. Is this car stock?
I find it very hard to believe you ate 3 qts of oil in 6K miles. And did not see it. Sounds like the car had issues .
OTOH Mitsu is not known for being lenient on their warranties. They will not honour them if they can get away with it.
Sorry to hear you got troubles. One of the above posters is right though..I would certainly think very hard about buying a car that had a blown engine at 14K even if it was replaced under warranty or completely rebuilt. There is absolutely no way to know if the car was bad from the factory...( now w/o warranty ) or it was severely abused or had no maintenance done or whatever. its too big a gamble.
I have 22k on my MR, it doesnt burn a drop, no noises, no dents etc and Im the second owner. I did have to replace the tires at 9k, that was because the previous owner had the alignment all screwed up. See my sig for new alignment. And I have 11 k on the YOKO ES100 with more than 1/2 tread left.
I fail to see how "so many owners" think the car has warranty issues and has bad trannies and clutches from the factory. Mitsu is not going to warranty an expensive car when it comes in modded out and the clutch judders at 1k or the engine needs replacing at 4k because the oil was not changed and the owner was practicing "a few launches at 6k but only once at the dragstrip"
The OP may not have done this but many people doabuse their cars and expect the manufacturer to stand behind abuse or neglect. I do not believe in that. However Mitsubishi should stand behind the car if there are no mods and the records are complete and valid. No excuses there.
I hope the owner gets something from Mitsu at the least.
My 2c
Milburn
My 2c
Milburn
#35
Besides it depends on how he drives the car. If those are track miles or hard miles and the car wasn't properly broken in I could definitely see it using that much oil in that time frame.
#36
besides burning oil did you ever check to see if you were leaking out oil. I know the crush washer on the drain bolt has a specific torque spec, could have leaked out some oil which in turned caused your dilemna. good luck with everything man. I sent my g/f out just now to go get my oil done now, got me all worried. better to be safe than sorry
#40
If you're going to spend the money at the dealership to get it fixed, might as well take it to a reputable Evo shop close to you have have it built. Your warranty is up shyte creek anyways. It'll be better than a factory rebuild for sure
#41
If i was keeping the car i would go buschur all the way. They have good stuff. I must admit it is tempting to keep it and rebuild it the way i would want it.
Yea i agree...definitely replace that little damn washer. Im positive it had a leak form there..i thought it was my truck. damn, still dont see how it could of been that much. O well, lesson learned..gotta check this stuff all the time. Pretty expensive lesson though!
If the dealer will put another warranty on the engine then ill go with them, other than that though i would rather give someone else my business. The dealer said 6100 to do it, Sun Devil Auto said 5700...those are the only quotes i have gotten so far. I am going to ask the dealer about a warranty tomorrow.
