alot of vibration when driving
Old Jun 3, 2007 | 04:18 PM
vmrevo9's Avatar
ok almost everytime i drive the car especially when it sits for a few days or so the car vibrates alot. it kinda feels like the tires need to be balanced. but once the car has be driven for a while it seems to go away. i thought it was the 19" toyos but i had put on the stockers and it did the same thing. has anyone experienced this before?
Old Jun 3, 2007 | 04:30 PM
Speed Corps's Avatar
Former Vendor
You know, it's the damndest thing. Mine does it too. I haven't figure it out yet.
Old Jun 3, 2007 | 04:31 PM
ak47po's Avatar
Tires are flat on one side.
Old Jun 3, 2007 | 04:33 PM
Former Vendor
No, first thing I checked was tire pressure.
redevoboy's Avatar
Have you had an alignment recently?
Old Jun 3, 2007 | 04:36 PM
ak47po's Avatar
No they get flat on the bottom from sitting for a long time.
Old Jun 3, 2007 | 04:38 PM
Curt@MrLed's Avatar
Former Vendor
110% right.
Old Jun 3, 2007 | 04:40 PM
evrblazin's Avatar
well if the same thing happens with two different set of wheels I would think it's an alignment or suspension issue
Old Jun 3, 2007 | 04:54 PM
psphinx81's Avatar
i would say get an alignment
Old Jun 3, 2007 | 04:57 PM
timllam10386's Avatar
After sitting for a while, the tires have a flat spot from contact with the ground.
Once your tire heats up it should be ok.
it's most pronounced when you drive in cold weather, let it sit for a day or two, and take it out again.
Old Jun 3, 2007 | 05:26 PM
hanahawaiian's Avatar
prob ur Wheel bearing gone bad
Old Jun 3, 2007 | 05:34 PM
jimsevo8's Avatar
When the vehicle sits for a while the part that is against the ground conforms to it and creates a flat spot. The flat spot should go away after a few minutes of driving. Some brands of tires are more prone to it than others. I think Pirellis are particularly bad for flat-spotting. This has nothing to do with an alignment and wheel bearings usually just make a howling noise and don't cause a vibration.
Old Jun 3, 2007 | 05:36 PM
vmrevo9's Avatar
thanks for the reply guys. it makes sense that it can be flat spots. today it was more pronounced but it did sit for a week. I also tend to baby it until it smooths out.
and for the alignment it got one before i got the car but i think i might get it redone since it does feel like it wants to pull to the right sometimes.
Old Jun 3, 2007 | 05:44 PM
jimsevo8's Avatar
Well, if it pulls to the right you might have a separated belt. Rotate the front tires to the back and see if it helps.
Old Jun 3, 2007 | 06:45 PM
fallen86's Avatar
check yooo tires, mine had the flat problem that was stated above
Quick Reply: alot of vibration when driving
