Greddy RS 1g flange for BR UICP 1g
Old Jun 11, 2007 | 12:55 AM
Perfect Tool's Avatar
I recently bought a Greddy Type RS BOV and I am trying to install it in place of my Buschur UICP with 1g BOV. Is there any way to install the Greddy with the 1g flange there? Is there an adapter kit anywhere, or should I drill out some holes? I searched, then figured it was better to ask you guys. I've looked for Greddy 1g adapters but have no luck, anywhere I can be directed to go? Thanks for the help guys
Old Jun 11, 2007 | 08:16 AM
91GSX's Avatar
Go to http://evo.dejonpowerhouse.com/ click on the bov tab & look about 1/2 way down the page. You will find your Greddy to 1g dsm bov adapter here.
I believe that the cheaper alternative is to mark & drill out holes in the 1G flange to bolt the greddy bov to it. Let me know how it goes & good luck.
Hope this is what you were looking for.
Old Jun 11, 2007 | 12:27 PM
Hey thanks man I really appreciate your help, exactly what I was looking for. I am thinking of doing the work myself and just drilling holes, just needed to know if this would be the correct solution and not a mistake. I am guessing if you do it yourself you need to use a 5/16" metal drill bit? I really hope I dont mess up but shouldn't if I use the Greddy gasket as an outline for the hole placement. I guess I'll try and drill it out.
Also would you recommend doing the single spring mod before even installing it in the first place? Also I forget, do you leave the small or big spring in there?
Old Jun 11, 2007 | 12:30 PM
4ringturncoat's Avatar
Just rotate the valve about 15 degrees and you will have plenty of material to drill/tap new holes. I did it and it works perfect.
Old Jun 11, 2007 | 01:29 PM
91GSX's Avatar
You are welcome, no problem at all. Yeah I would suggest doing the single spring mod before throwing it in. evomoto.com has a write up on how to do the single spring mod. You ditch the smaller spring.
Old Jun 12, 2007 | 12:24 AM
Well I went ahead and drilled out the holes on the flange, came out pretty good but I forgot that my standard tap and die set will not work for threading the hole. I went to Walmart at midnight to look for a metric since it was the only place open to buy one but they didn't have it. Tomorrow evening I'm going to Sears to see if they have a metric one, if its more expensive than the flange itself I'm just going to buy the adapter. I dont need a tap and die set but if its cheap I'll get it.
Also the way the BOV is turned there will be somewhat of a little pinch in the line in the recirc part, even a little would be bad right? I may have to buy a new hose too. I'll take some pics when its done
Old Jun 12, 2007 | 01:56 AM
Well I just looked online at Sears and its $30 for a crappy 15pc tap set and hundreds of dollars for a nice one, I'm just going to buy the adapter, thanks for the help guys my car will be in show and shine here soon when I get my new wheels on
Old Jun 12, 2007 | 05:02 AM
The bolts go throught the bov flange, just tap it for a 1/4" allen bolt and you will be fine. Get new allen bolts at Lowes and call it a day. Make sure you do the single spring mod, I adjusted mine as tight as I could without the car stalling.
Old Jun 12, 2007 | 09:27 AM
I wish I would have known that sooner I already ordered the adapter. Crap
Yeah I already did the spring mod hope everything works good
Thanks for the help
Viciouz
Mar 26, 2009 09:39 PM
evo8dustu
Jul 6, 2008 05:43 PM
wrxedout
Jan 11, 2008 09:17 AM
evobeatsti
23
Jul 18, 2007 01:23 PM
ct9a gsr
Jun 27, 2005 11:45 AM
Quick Reply: Greddy RS 1g flange for BR UICP 1g
