Compustar Alarm verification please...
#31
alright, well my alarm is working now ...
we hooked up the dei module, 454t (tach signal amp) .... went to the brain and it picked up the tach signal immediately. then after some testing, we found out that the clutch bypass that we installed was not working. strangely enough, just disconnecting the clutch sensor plug from the clutch sensor works fine, the remote start works and i no longer need the clutch in to start my car. thanks for everyones help and ideas.
#32
check your battery. mine is an 05, and my battery is starting to get a little weak, there are some voltage issues, only way i realize it is the battery, is cause the voltage sensor on my SAFC is showing it, i thought it was a local problem ( mine is the radio lights, and hvac lights) at first, i'm going to get a new battery this weekend.
#33
#34
yeah, we originally had a relay there. thats how i had it on my last evo as well.... but after dealing with the BS for 2.5 days now, after we found out that was the problem, and the alarm worked fine without the sensor connected, it was perfectly fine with me.
fyreant
87
Jan 6, 2012 09:54 PM
DANMEND
Evo X How Tos / Installations
Aug 5, 2008 05:16 AM
freedom
Apr 12, 2004 08:38 PM
