AEM UEGO Wide Band O2 Gauge
I have an AEM UEGO Wide Band O2 Gauge. I am pretty new to this but im learning. I just want to know how to adjust my A\F' ratios. What do I need to hook it up. Thanks for any input.
The guage is not going to let you change your a/f's.
To answer the question, I removed my 2nd o2 sensor and used the bung to plug in my Uego. Tap power off the fuse block behind the coin tray by your left knee and you can find a common ground in there too. Remove passenger seat to run the sensor wire from the 2nd o2 bung to where ever you plan to mount the gauge.
GL
GL
its better to weld an additional bung into your dp because you want the sensor to be placed before the cat (unless your running a test pipe). Also this will keep from getting a check engine light from not having your secondary O2 hooked up and you wont have to worry about putting it in an taking it out whenever you want to log your afr's.
For changing afr's you need a laptop and ecuflash and a tactrix cable but unless you know what your doing seek a "proffessional" because you dont want to hurt your motor because you changed it without knowing why or what to change it to.
Thats my .02
Thats my .02
how do you connect the "AEM UEGO Wide Band " to ur laptop? I searched and found that people use/cross wires of some sort to get it to work with evoscan.
everyone claims it's easy, but does anyone make this wire ready? im willing to pay someone to make it for me.
thanks
thanks
If you have the manual, it tells you what pins to use on a Serial connector. You connect one wire for the signal to the laptop, and one for grounding. My laptop has a serial connection on it, but some of the newer ones dont. I believe you have to get some sort of convertor (radio shack?) to usb if you dont have the connection.
cpunlamd
Jun 6, 2010 03:20 PM
