View Poll Results: Gear or nOt?
in Gear
100
42.02%
not in Gear
138
57.98%
Voters: 238. You may not vote on this poll
Leave Car in Gear or not?
#31
I never do, I would forget its in gear when I start it and stall abruptly.
Similar topic,
Is it just my car or do you guys have to pull the E-brake entirely up for it to hold the car totally. For instance if its not a click or two from the top position will your car roll slightly?
Similar topic,
Manual says 5-7 clicks should engage the parking brake fully.
#33
I always put my parking brake on and leave it in 1st unless I'm facing downhil, in which case I leave it in reverse. The most important thing to remember is to let the car settle on the parking brake in neutral, then shut the car down, wait for the engine to fully stop rotating, then put it in gear. This saves the transmission from staying in a loaded state the entire time it is parked. This is also the correct way to leave a car in 'park'. I can't stand when people put a car in park and let the weight of the car settle on the transmission. That's what the parking brake is for!
#34
I've been using the e-brake only since day 1, but i've noticed now that I have to pull the e-brake all the way up to hold the car on a steep hill. Now I put the load on the e-brake and put it in gear.
Does anyone know if leaving the car in gear without the e-brake can put stress on the tranny and ruin something?
#37
#41
remote start in an Evo ??? FWIW ebrake & in gear all the time . If you don't use the ebrake all winter long you run the risk of having those high quality mitsu cables get frozen with salt and rust build-up , my humble .02 .
#42
I don't leave my Evo in 1st gear anymore, because I unplugged the clutch starter switch, so I no longer need to push in the clutch pedal to start the car. Therefore, I need the car out of gear in order to do this. I will put it in gear if I'm on a hill, of course, but that's rare.
#43
#44
That's how mine was, but I adjusted it. Search the how-to section for it. It made a huge difference for me. It's much tighter and I have confidence in it now, so I leave it in neutral almost always now.
#45
