Fujita Intake..
Old Aug 2, 2007, 03:56 PM
  #31
SoCalRedLine's Avatar
^i havent had any problems with mine. Im still on stockish boost (21-18psi) and have no boost leaks. I checked mine for leaks like crazy when i first installed it, found a few leaks near the TB...but most of the connections are rolled, the only 2 that arent are the connection from the IC and the connection to the TB (lol, where most pipes get seperated...).
Old Aug 2, 2007, 04:01 PM
  #32
Former Vendor
Speed Corps's Avatar
I'm glad to hear you haven't had any problems with it. It is a very nice kit. Do yourself a favor and find someone with a bead roller to bead the pipe ends before you start turning up the boost. I had some I/C pipes on my old eclipse that werent rolled. When I turned up the boost to 25lbs on a 20g, the pipes blew off and it sounded like a shotgun blast. It scared the crap out me.
Old Aug 2, 2007, 04:06 PM
  #33
^ill just take them into my welding class and lay a bead down on it with the heliarc. or put tabs on there with brackets...lol...for 40psi...
Old Aug 2, 2007, 04:45 PM
  #34
AtO-MiX's Avatar
Originally Posted by SoCalRedLine
^yea, thats what Bryan recommended. Isnt that basically the same as the ebay one?
I believe that they are pretty much the same I could be wrong. I dont have alot of Buschur parts (in fact I am pretty sure its my only one) but the air filter is by far one of the best things I have bought for my evo.
Old Aug 2, 2007, 05:03 PM
  #35
Bonestock!'s Avatar
Originally Posted by Speed Corps
The Fujita comes with upper and lower I/C pipes but if the ends aren't rolled, you'll be hating life when the pipes keep blowing off. I use the Injen kit and have no complaints.
My Injen blew off half way through my second lap of the Nurburgring!
Old Aug 3, 2007, 06:47 AM
  #36
JDM_MR's Avatar
MY IC pipes got damaged and instead of going back OEM, I want to upgrade the whole IC piping.
Com'n guys, tell which brand to purchase, the Injen or the Fujita as the price difference between the two is minuscule .......
Old Aug 3, 2007, 08:11 AM
  #37
Former Vendor
Injen
