Restrictor Pill Replacement
Old Jul 8, 2007 | 02:33 AM
Grey Razor's Avatar
Can anyone tell me where I can find/buy a replacement restrictor pill for the boost lines? Currently I only have the one pill closest to the turbo and I am missing the one that is closest to the solenoid. I am trying to return back to the stock boost setup. My boost has been spiking up to 1.5+ bar and it's making me very uncomfortable. Is it very dangerous to be running without this particular pill installed on a stock tune? I know that the absence of this pill increases boost by almost 2psi, but I am concerned that I am causing detrimental damage to the engine by not having it there. Any information would be greatly appreciated.
Old Jul 8, 2007 | 02:49 AM
WTF_LOL's Avatar
www.mitsubishiparts.net
part #mn143555
nd you get the hose and the pills. I have never seen anywhere that you can buy JUST the pills...
I ordered one and it arived about 3 days later
Old Jul 8, 2007 | 02:56 AM
WTF_LOL's Avatar
Originally Posted by Grey Razor
...it's making me very uncomfortable. Is it very dangerous to be running without this particular pill installed on a stock tune?....
I would say that increasing boost, without tuning for it, by removing factory parts tha smooth out spikes and without a real good way of knowing what your boost is, IS a bad idea. YOu are probably not doing detramental damage by only bumping it up a couple PSI but, you are "rolling the dice".
Just have your ECU flashed if you want to increase power. When my car was basically stock, I threw in a fuel pump and had it flashed and I was surprise how much it changed the car's power delivery and how well boost can be controlled with a flash... Only problem with that is I started spending every paycheck looking for that same "first hit!"
Old Jul 8, 2007 | 08:20 AM
I-Dom-In-8's Avatar
I'm pretty sure i still have mine sitting in the garage, I took it apart just to see what it looked like, If i still have it i will pm you and send it to you, Only thing i see being the problem is trying to get just the pill back in..I will get back to ya either way..
Old Jul 8, 2007 | 08:42 AM
Forrest Gump 9's Avatar
Can some one please show me a picture of what this "boost restrictor pill" looks like? Thanks in advance.
Old Jul 8, 2007 | 10:47 AM
Grey Razor's Avatar
Basically it is just a small brass cylinder with a tiny hole in the center... There are two of these little guys:
This image is currently found on Vishnu's website which can be found here:
http://www.vishnutuning.com/evo_install_pill.htm
Old Jul 8, 2007 | 11:01 AM
Thanks you sir!!
Old Jul 8, 2007 | 03:42 PM
I-Dom-In-8's Avatar
Sorry dude looked in my garage and couldnt find it..
Old Jul 9, 2007 | 01:31 AM
Grey Razor's Avatar
Ah, that's cool man. I appreciate you taking the time to look for it though, thank you!
Old Mar 21, 2011 | 11:55 AM
madeinjapan's Avatar
Bump from the dead - Can you physically feel the pills if you pinch the lines? I'm working on solving an 11psi boost issue and can't feel the pills but am not really sure if I would be able to if I tried. TIA.
xXVicariousXx
Mar 3, 2017 11:36 AM
XstormtrooperX
Jan 19, 2015 09:59 AM
evohmoob
Sep 21, 2013 07:58 PM
fearless857
Dec 17, 2011 05:05 PM
honda-guy
Mar 23, 2011 02:52 PM
