ACD Fluid Question
ACD Fluid Question
My ACD fluid level is a bit low. I've bought some ACD fluid from the dealer, so now do I just add it to the ACD reserve? Or do I need to flush it? I'm hoping I just need to pour it in and be done with it. Thanks for any help.
I hope you know that after driving the car that the fluid level goes down in the reserve,and after sitting for a while it comes back up to full.This is normal so only check your level with the car cold.Dont check it after you drive or everytime you will think your low.BTW if after checking it after sitting all night and it needs some,just add and your done,no bleeding or anything like that unless it goes dry. Then you would first have to find the leak.
