Defi installed. Questions...
Old Jul 28, 2007, 11:21 AM
Evo Tengoku's Avatar
Just finished up a 60MM DEFI BF Boost (Imperial) gauge install with CUII.
When the opening ceremony starts, its does the full sweep forward but coming back it ticks. Just wondering if this was normal?
Also, I was tuned for 22PSI. The Defi peaked at 24PSI. Are defi's inaccurate?
Thanks in advance.
Old Jul 28, 2007, 11:35 AM
Robevo RS's Avatar
yes.
i have tuned by Sean Ivey at 23 psi and my defi shows 25psi...
Old Jul 28, 2007, 01:23 PM
Is your opening ceremony similar to what I described?
Old Jul 28, 2007, 01:49 PM
Robevo RS's Avatar
i got the full sweep up and down as you have .
I do not know what the "ticks" means.
sorry my english is not too great.
Old Jul 28, 2007, 01:56 PM
Full sweep up is very smooth.
Full sweep down is not smooth. Ticking like a clock.
Old Jul 28, 2007, 02:05 PM
Spookpur's Avatar
I have the Defi Blue Racer Gauges, and I haven't heard any ticking coming from any of the 3 I have installed. I'll chime in later when I have AMS tune my car, too see if the boost gauge matches what it's tuned for.
Old Jul 28, 2007, 02:13 PM
well the ticking isnt a sound. its the needle "ticking" back down on the full sweep. Its hard to capture on video
Old Jul 28, 2007, 02:15 PM
erratic evo's Avatar
Thanks in advance.
My friend has the exact same gauges ( look awesome!) but his sweeps smoothly back into place, no ticking or hesitations. As for psi being off by 2 psi must be part of the issue. I was with him when he was getting dynoed and no one ( tech or my friend complained of offset boost #'s of gauges compared to datalogs. Check with whomever you purchased your gauges or the manufacturer site for question or answers. Good luck
jhanksevo's Avatar
i think it is normal mine does the same thing and when i got dyno tuned mine was inaccurate by 2psi also
Old Jul 28, 2007, 02:22 PM
Robevo RS's Avatar
yes mine is coming back as smooth as going up.
Old Jul 28, 2007, 02:52 PM
Eggy's Avatar
mine all are a bit "ticky" going back. It's normal.
Old Aug 2, 2007, 09:04 AM
BoOsTinGEVO190's Avatar
so the defi bf gauges are off by 2 psi seem a little to much
I also have that gauge
Old Aug 2, 2007, 09:22 AM
Does anyone know if the supplied "T" fitting with defi's has some sort of built in restrictor? I used the factory "T" fitting (sports meter kit) and am thinking this might be the reason I am reading 2PSI off.
Old Aug 2, 2007, 09:28 AM
Sap12687's Avatar
No there is no restrictor in the T. If your gauge was reading 10psi or 30psi i would worry. You dont have a problem.
Opening ceremony is supposed to be like that. The lights just flash very quickly and give it the "ticking" effect. Needle is actually moving at a constant speed.
Old Aug 2, 2007, 09:33 AM
milo's Avatar
My tee didn't come with a restrictor. My Blitz SBC boost controler and Defi are reading the same but they are using the same signal source.
