service engine soon light came on
Ok i was driving my car last night and it has 3800 miles.....i know i needed to change my oil and the light just came on......is there something wrong or does it do that to tell me i need my first oil change? Also if i did it myself will that ruin my warrenty?
A P0300 OBD code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
Just got back from the dealer..it was a misfire. They said sometimes different gas companies gas will mess it up...dont ask me why but thats what the guy said and he owned an evo as well. So thanks for the help guys, much appreciated
misfire
I know this happend alot on the VIIIs but not the IXs. I didn't receive any P0300 codes until I had the cosworth cams put in. So with a TBE, MBC and high flow cat I never got any codes pop up. What kind of gas did you use? I use to put in anything as long as it was cheap. Now I only use Unocal 76.
