Cams and Header just delivered =D
Cosworth M1
Advertised Duration - 240 deg Int / 240 deg
Duration - ___ deg @ 1mm Int / ___ deg @1mm Exh
Lift - 10.2mm Int / 10.2mm Exh
Lobe Centerlines - 107 deg Int / 113 deg Exh
LSA - 110 deg
Upgraded valve springs recommended
Cosworth M2
Advertised Duration- 252 deg Int / 246 deg Exh
Effective Duration - ___ deg @ 1mm Int / ___ deg @1mm Exh
Lift- 11.0mm Int / 11.0mm Exh
LSA - 110 deg
LSA - 110 deg
Cosworth M2
LSA - 110 deg
