20G Question
Old Aug 27, 2007 | 07:22 PM
holyfrickster's Avatar
20G Question
Hey guys do you know if it is possible to buy the 20g9lt, Just the turbo not the hotside or wastegate setup or anything?
Old Aug 27, 2007 | 07:53 PM
mhgsx's Avatar
Do you have the means to machine the hotside to accomodate the bigger turbine wheel?
Old Aug 27, 2007 | 08:00 PM
MitsuJoe's Avatar
What are you trying to save here? You ever tried porting the hard cast steel found in the hotside/manifold?
Old Aug 27, 2007 | 09:05 PM
sparky's Avatar
Although externally the 20G-LT resembles the factory IX turbo, both the compressor housing and the turbine housing require extensive machining to accomodate the larger wheels.
If you want a 20G-LT, just buy a IX turbo and send it in to FP and wait your turn. You can in fact, utilize the stock IX wastegate on the 20G-LT though. Maybe you could save a bit there.
Alternately, you could have your '03 turbo converted to factory IX turbo specs though by swapping out the VIII compressor housing and your old 9.8 cm turbine housing for the IX compressor housing and a 10.5 cm turbine housing. This would be within the realm of the possible. Just send it off to Blouche Turbos.
Old Aug 27, 2007 | 09:14 PM
KenMasters's Avatar
Factory IX turbo's spin about 30k rpm's faster than an VIII's , I don't care what housing you swapp on it.
Search for "turbo flow rates" In that thread you can actually see the IX's yurbo has a larger comp housing.
Old Aug 27, 2007 | 09:15 PM
Speed Corps's Avatar
Former Vendor
They probably won't sell any of the parts seperately since the wheels will need to be balanced and the housings needs machining.
Old Aug 27, 2007 | 09:21 PM
sparky's Avatar
Originally Posted by KenMasters
Factory IX turbo's spin about 30k rpm's faster than an VIII's , I don't care what housing you swapp on it.Search for "turbo flow rates" In that thread you can actually see the IX's yurbo has a larger comp housing.
Huh? So? What are you referencing anyway? Where did you glean the 30,000 RPM tidbit from? Are we talking USDM IX vs. USDM VIII turbos? No one is gonna argue that a IX 16G turbo doesn't outflow an VIII 16G. So, what is your point?
Old Aug 27, 2007 | 09:33 PM
sparky's Avatar
EDIT: deleted repeat post.
Old Aug 27, 2007 | 09:37 PM
KenMasters's Avatar
You can not torn an 8 turbo into a 9. That is my point, I don't care who you send it to,
And Mitsubishi is my source of info for the 30k rpm difference.
Old Aug 27, 2007 | 09:42 PM
sparky's Avatar
Never say never!
Old Aug 27, 2007 | 09:54 PM
KenMasters's Avatar
Never!!!!!!!!!!!!!!
Ha Ha JK, Sparky we need to have beer together.
Old Aug 27, 2007 | 09:56 PM
PhoPoweR's Avatar
Did the 2004 evo come with the 20g?
Old Aug 27, 2007 | 09:58 PM
KenMasters's Avatar
No evo comes w/ a 20g
Old Aug 27, 2007 | 10:03 PM
sparky's Avatar
You can not torn an 8 turbo into a 9. That is my point......
What would you say if I told you that yes, in fact it is doable? And that, furthermore it is, at least as far as I know a relatively simple conversion. Blouche can do it with his eyes shut.
To further pique your incredulity, you also can reconfigure a IX turbo back into being an VIII turbo. Although, I don't know why anyone would want to make that conversion. But, it can be done.
The 30,000 RPM difference, however, is a wickedly misleading bit of misinformation which can only exist in your imagination as it is totally unsubstantiated and defies corroborant foundation.
Old Aug 27, 2007 | 10:06 PM
It does not matter what I am capable of making to accomodate the 20g turbo. I am merely just asking if you are able to buy the 20g. Just the turbo not the rest. thats it. Not a matter of trying to find a cheap way around it. Just if i do not need it then why buy? Just asking. Don't need to get all crazy with me. Thank you to who actually giving me decent input.
