Drive Shaft Vibration in the Rain ... HELP!
#32
it could be a number of things causing this rubbing of the driveshaft. In my case, i think installing the cutout may have slightly changed the angle of my exhaust which is now causing the rubbing noise in rain. It could also be my ****ty gen 1 invidia downpipe that fits like crap. Either way, at least we know its exhaust related
#33
AWESOME!! I will go check, thanks for the photo. I have the RMR exhaust, bought it in '03. Never had the rain issue, till this year. Exhaust has been on and off alot this year and last, might have to adjust it some!
Your issue may not be the same issue that the OP is describing. Take it to the dealer if it's stock. In the case of the original poster with the HKS exhaust.. here's his problem. 1 finger of clearance is not enough, I had like 3/4" of clearance and mine still rubbed. I also noticed it did it much more in the rain but mine would rub going aorund corners sometimes as well as in the rain. It sounds like brakes dragging on the rotor or just a nasty metal to metal sound. I searched high and low and finally saw what was the problem when my car was on a lift. There are someone elses pictures but I experienced this as well. The part of the driveshaft in these pics is supposed to be black.. not bare metal. What's weird is that it didnt happen immediatly after putting the exhaust on the car, it waited about a month to start rubbing. Maybe it is a heat issue, either way I got rid of the HKS, got a Tanabe Concept G TBE and my issue is gone. For such an over priced exhaust (HKS) it should fit like a glove, instead of fitting worse than a ebay exhaust. Honestly I think the reason this hasnt come up before is everyone is too embarassed that they spent so much money for such a POS product. I was that way too for a while and now I just dont care. HKS exhaust is Junk, at least on my IX MR it was.
I called HKS and they insisted no fitment issue with their exhaust and told me I needed to loosen all the bolts and move it right. I had already dont that and told them so and they offered no other solution. If they would have put that resonator 6" back this wouldnt be an issue. Design flaw! my car is not lowered nor does lowering or not lowered affect the exhaust location.
#34
Has there been a conclusive finding to this issue, to those who don't have the exhaust touching the driveshaft. For me, now the vibration is even occuring in cold temprature.
#36
i have the same problem in the rain drives me nuts and I'm stock height with gsc exhaust ..even after i adjusted it to get it off the driveshaft still does it ... kinda wondering if the driveshaft now could be out of balance from rubbing the exhaust for a week or two
#37
But that is the thing there is no sign of rubbing on the exhaust piping or anywhere else?? I just recently got my clutch replaced...and I do know they remove the DP and Cat, to install the clutch...now a new problem, my exhaust is making that noise/vibration/choking noise like it is raining in the dry weather.....hmmm I am putting it up on the ramps tonight to examine for improper alignment of the piping?? IDK
#39
It happen to me today really bad, stock ride height, HKS Cabon Tit exhast.
girth5785
Jul 27, 2016 08:27 AM
seiya
Lancer Engine Management / Tuning Forums
Jul 26, 2012 09:43 AM
wicked white14
16
Apr 20, 2012 02:53 PM
