constant boost
people have had more than 550 to the wheels on stock ecu...
and more than 450 to the wheels on stock motor...
03 evo 8 would be hard to hold a constant boost.. but with a dyno tune you can get pretty close especially with an EBC...
You'll obviously never see much boost before 3 grand. From there, there is a way to hold boost pretty good. Sorry, I'm not much help, but it has something to do with some solenoid mod you can do. With a MBC, I don't care who you are, if you're still on the stock turbo and WGA, you will not hold boost solid! It will taper some. People that say they are on the stock turbo, peak at 22 psi and hold rock solid until redline are insane. It just doesn't happen. Stock Turbo = taper, unless you do that special mod. Even then it doesn't hold rock solid.
