Max Egt and Oil pressure?
The question is what is the max and average for egt and oil pressure. This is for a dd IX. Around town and the track. I guess what is the safe range of these gauges. Just got boost, egt, oil pressure defi's done yesterday and they are pretty much the standard type gauges that people get but what is the reason behind them besides the obvious boost? Did searches by the way.
On my defi my EGT's ussually run around 1500-1550 at about 80 on the highway. but the numbers all depend on which tube you put your egt probe on, how far from the head, and if your using an aftermarket header.
your egt probe is always suppose to be in the exhaust manifold. you need the reading before it goes into the turbo, for it to be after the turbo it is kind of useless.
And on the EGT gauge.... if you have it mounted after the turbo, it's going to be hard to draw comparisons about what is the proper temperature range. Like someone else posted, it should be pre turbo, and even then, it's going to be car setup/ tune specific and hard to pinpoint the proper range with datalogging your individual setup.
that's normal for the Evo, oil pressure at idle, once the car is hot is rediculously low, I forget the exact numbers, but the service manual states the limits, and the low side is around 7 psi IIRC. But on a cold motor, and rpm's around 3000, you'll see close to 90 psi with 10w30 motor oil. Once it warms up, it drops significantly. The point I'm trying to make is, it's a wide range, and very dependent on oil temperature. It's tuff to set the Defi gauge alarm to be meaningful since it's so temperature dependent. It's either going off at idle once warm, or it's not protecting you at all.
Happy Hazard
Jan 31, 2008 07:10 AM
evo8rcr
57
Nov 26, 2007 12:48 PM
